adding sound deadening material
Old Mar 24, 2009 | 06:04 PM
mykim72's Avatar
mykim72
Default adding sound deadening material
so i was reading in the DIY section and there was something that was unclear. If you add the material onto the door, that it may absorb water and rust the door, which sounds correct. how do you put it on the door then? without it absorbing water?
Old Mar 24, 2009 | 11:05 PM
ttocs's Avatar
ttocs
most of the good stuff is a butyl rubber compond with a foil wrapper. Not sure how rubber or foil will absorb water.......
Unless you are doing it in the rain, it isn't a problem. I use a damp rag to wipe down the surface to clean it before I put mine on, it is often recomended in the installation instructions.
mungodrums
Oct 7, 2015 04:01 AM
mungodrums
Sep 29, 2015 09:18 PM
Gkid182
Sep 22, 2015 08:17 AM
Sep 17, 2015 07:57 PM
