Sound System
Old Apr 28, 2009 | 07:38 PM
The_Saint's Avatar
The_Saint
Default Sound System
I'm thinking of installing a sound system in my 66' Coupe. I'm actually restoring it, but I'm almost done. What remains to be done, is ordering an alternator. I've got two small(ish) Roadmaster speakers on the top of the back seats, and I'm ordering two large speakers to put on the front kick panels. I'm thinking of possibly adding two more 6 1/2 inch speakers, and a subwoofer. How big of an alternator would I need, in terms of amperage? I'm thinking of putting in a 95A, but I might move it up to 130A. Any input would help. Thanks.
EDIT: These are the kick panel speakers that I'm putting in: http://www.mustangsunlimited.com/ite...atKey=EMUSTANG
Will this fill up the car with sound?. I'm not sure what the speakers on the top of the back seats are, but they work pretty well. They were there when I bought the car.
Would I need a subwoofer, or would those suffice? I don't really listen to any rap, but I'd like the added bass.
Any help would be much appreciated. I know nothing about speakers, or wiring. Thanks
Old Apr 29, 2009 | 07:10 AM
5pointslow91's Avatar
5pointslow91
hav a 140 amp in my current 91 stang with just after market speakers n the headlites flicker sum but i think the car has sum electrical probs, i bought a big 200 amp alt n optima bat 4 my truck which has 3 JLsubs and amped interior speakers and off road lights and its held up a few yrs now
Old Apr 29, 2009 | 07:11 AM
5pointslow91
Originally Posted by The_Saint
I
as for sound, aslong as you amp up your interior speakers they should sound good aslong as ur not buying sum cheap flea market ****
Old Apr 29, 2009 | 12:22 PM
ttocs's Avatar
ttocs
the link is bad.
PReal is our early model stereo expert but is not on here as much as he used to be. You might try a pm.
Old Apr 29, 2009 | 07:37 PM
PReal's Avatar
PReal
Preal to the rescue.
You can run a couple small amp off of the factory alt but your voltage will bounce around a little at idle.
In my car I have e 5.25"' comp set in some kick panels I build with around 60 watts per channel powering them.
An eclipse CD player in the dash.
I also have 2 12's in the trunk with around 50 watts to each and a couple 6.5 midbass drivers on the rear package tray (low crossed at roughly 500 hz).
The stereo has a ton of volume but lacks some of the midrage clarity I am used to in some of my newer cars.
If you are looking into decent sound with some bass get a setup like this...
6.5's in front kicks and in the rear package tray.
Power them with a small 4 channel amp
Get yourself a 10' or 12" woofer and run around 150 watts rms to it.
If you have an aftermarket CD player, you could run your rear speakers off of the HU and get a single 4 channel amp for the fronts and subs.
I typically don't recommend rear speakers and do not run them full range in any of may cars, but if you are not a sound quality freak you should be very happy with a setup like that mentioned above.
If you need some recommendations on brands and installation, let me know.
Vrooom
Feb 21, 2016 05:25 PM
2015Ecoboost
Sep 17, 2015 01:48 PM
Sep 10, 2015 08:39 PM
robjh22
Suspension
Sep 8, 2015 12:47 PM
cbird1177711
Sep 3, 2015 08:43 PM
