New AVIC-90BT need help with wiring
I found the site today and I don't I got the right wire now I'm confused...
I think I was tapping into the Tach sensor and I'm going to find another white/orange wire. This is getting frustraing
http://www.the12volt.com/installbay/....asp?TID=27819
...http://www.the12volt.com/installbay/....asp?TID=27819
Your tach wire is located at the ignition coil or coil pack UNDER the hood......
Speed sense(VSS)----white/orange.... pin 68 at the PCM high in the pass kick panel....You can trace the wire from the PCM to Black plug lower in the pass kick between the 2 gray plugs. I never heard anyone call that a tach sensor....they are just confusing you..... That is the locatation of the wire, sh*t I beleive that is the only white/orange wire down there anyways.
jwog666
Dec 27, 2021 08:09 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
