Automatic vs. Whip Antenna?
Old May 24, 2009 | 07:38 PM
dsadams's Avatar
dsadams
Question Automatic vs. Whip Antenna?
I have a '98 Cobra that has a whip antenna which makes it difficult to put on a car cover. I'm considering putting in an automatic (retracting) antenna but I'm not sure if this is wise or not? I'm also very uncertain as to where to purchase an automatic antenna. Does Ford make one that will work? Is there an aftermarket supplier? Am I going to have trouble getting it to install clean? Any advice would be very much appreciated!
Old May 24, 2009 | 10:35 PM
ttocs's Avatar
ttocs
it will take a bit of work to put in a power antenna both on the fabrication side to mount it, as well as in body/paint.
Have you ever considered carring a small adjustable wrench and just removing the mast? I bet it would waste a whole 15-20 secs, how long do you struggle with it now?
Old May 26, 2009 | 05:32 PM
dsadams's Avatar
dsadams
Cool Interesting
Interesting, so there isn't a 1:1 replacement option? Hmmm... I suppose the next best option is to buy one of these short antennas (8" or 14") and just replace the tall one that came stock with the car. That way it would be easier to lift the cover over the antenna. It still means that the cover will have a hole in it for the antenna but maybe that's something I can live with.
Old May 27, 2009 | 08:23 AM
GTRedfire03's Avatar
GTRedfire03
Metra makes an amped windsheild antenna that you can use.... 44-ua200
kevsgt
Oct 9, 2015 10:12 PM
b8checker
Oct 8, 2015 12:55 PM
b8checker
Sep 30, 2015 07:11 AM
wraith777
Sep 28, 2015 10:49 AM
