Audiobahn subs- Good or Bad?
I'm thinkin of putting a box with Audiobahn AW1251T Subwoofers in and I don't really know anything about them.Now I'm not trying to rattle my neighbors teeth out,but I'd like something that sounds half way decent.I know you all have your favorite subs but I'm not looking to spend a grand on an enclosure just want to know if Audiobahn is crap or not. THANKS!!
On paper it looks good
Rec. Sealed Box Dims: 1.00 - 2.00 cu.ft.
Rec. Ported Box Dims: 1.30 - 3.15 cu.ft.
Free Air Usage: not recommended
Sensitivity: 92.1 dB
Frequency Response: 24-1000 Hz
Recommended RMS Power: 400W
Peak Power Handling: 800W
Impedance: dual 4 ohms
But the sound also depends quite a bit on the enclosure type you choose: single, dual, third order, forth order bandpass, the Cubic feet given to each speaker, port length and diameter, and the type of amp you feed it with.
You dont have the money for jl if your only willing to spend a grand, i'd go with a kicker l7 with one of the new planet audio amps, or some kind of memphis hpo...Audiobahn is overrated, horrible...
from experience audiobahns look beefy and cool (flames etc.) but there are a lot of other brands that out perform them. If you want awesome subs stick with MTX, kicker, JL audio and alpine. MTX used to be kinda crappy but they are makin some kick a$#$$$ subs these days.... I have 2 12" pioneer subs which were givin to me, i bridged them at 4 ohms and they hit hard! Right now im savin up for 2 12" alpine type r's and 2 alpine 400 watt rms amps so that each sub has its own amp, im making a custom enclosure to fit the specs and a fully dynamated trunk, the setup should be pretty impressive once im done ill post pics up but it might be a month or 2 before i get the setup in....[&o]
