where is my weakness?
Old Aug 20, 2009 | 06:55 AM
sandcracker21's Avatar
sandcracker21
Default where is my weakness?
well i have added two 12inch kickers and a 300 watt kicker amp to my mach460 system...
now i have a kenwood 6140 HU as well
all speakers and two mach amps still 'stock'
my question is, where is my weak link? if i change one more thing, what should it be? where is my money best spent at this point?
thanks all!
Old Aug 20, 2009 | 08:13 AM
ttocs's Avatar
ttocs
I would spend $20 for passive cross-overs(capacitors) for your tweets to take the bass out of them. and bypass the factory amp for them and use your deck to power them. I show how to bypass the amp on page 2 of my cardomian page.
Old Aug 20, 2009 | 04:36 PM
sandcracker21
how dificult is it to install something like this? i probably sound like an idiot , but i dont know much about car audio (learning more every day it seems) the tweets are the lower door speakers right?
Old Aug 22, 2009 | 07:45 PM
sandcracker21
is it possible to replace all the speakers with better aftermarket speaker and run them "plug and play" with the stock mach 460 amps ?
or would i have to gut the entire thing?
the system sounds pretty bad now with my dnx6140....bass is distorted a little and sounds 'hollow' and it seems like the speakers cant get up to par, when i put a little volume into them they distort as well
Old Aug 24, 2009 | 05:46 PM
sandcracker21
bbump
Old Aug 24, 2009 | 06:42 PM
pentavolvo's Avatar
pentavolvo
IMO get 2 sets of 5x7 coaxials the polk db571 is a great speaker and bypass ur factory amp and it should sound alot better
Old Aug 24, 2009 | 10:26 PM
sandcracker21
5x7 speakers would the door speakers (on bottom) correct? this seems like a good place to go, but the most distortion seems to be coming form the 'tweeter pods' (upper door)
if i puchase new higher quality speakers for this, would it just be a 'plug and play' set up or would i have to rewire it all the way through?
Old Aug 25, 2009 | 05:53 AM
pentavolvo's Avatar
pentavolvo
as posted just rewire it and bypass the crappy factory amp. i forgot you have the door tweeters either unhook them or get a component set instead
Old Aug 25, 2009 | 07:12 AM
sandcracker21
will bypassing the factory amps make that much of a difference? i am not comfortable rewiring system my self and dont want to have to pay someone to do it either
now if i simply disconnect the tweeters on the top of the door this will not cause a problem? the one on the passanger side is blown out and rattles like mad, driving me crazy
Old Aug 25, 2009 | 04:10 PM
pentavolvo's Avatar
pentavolvo
not gonna hurt anything by disconencting it. IMO the factory amp is garbage and u are limiting ur self by trying to use it
