help with setup on a 2002!
Old Sep 17, 2009 | 05:07 PM
jmsjags's Avatar
jmsjags
Default help with setup on a 2002!
a while back i removed the 2 subs from the trunk and left 1 amp back there to power the door speakers. i recently replaced the 2 door speakers with 2 kenwood 6x8's. the sound quality is amazing except for the fact that my bass will cut out when it gets to a certain loudness. basically i can't turn my music up as loud as i would like it because then the bass will cut out and it'll sound like ****. how do i fix this problem it's driving me nuts!
Old Sep 17, 2009 | 06:41 PM
JayMax03's Avatar
JayMax03
whats the specs on the amp and the kenwood 6x8s, do you have it on the high-pass or low-pass filter settings on the amp?
Old Sep 18, 2009 | 08:37 AM
jmsjags's Avatar
jmsjags
well its the stock mach sound system amp. i'm not good with electronics so i don't know how to change the settings or anything
Old Sep 18, 2009 | 10:24 PM
flood41's Avatar
flood41
the amp is clipping because the speakers that you installed are 4 ohm and the amp is made to run at 8 ohm.
Old Sep 20, 2009 | 12:06 AM
ttocs's Avatar
ttocs
wut he said..........
If you have replaced the deck you can bypass the amps and the power the speakers off of the deck. I show the bypass harness on page 2 of my cardomain page.
Old Sep 21, 2009 | 01:46 AM
JayMax03's Avatar
JayMax03
cr620
Oct 3, 2022 10:18 PM
mrtrodonet
Sep 19, 2020 03:12 PM
fastbackford351
Oct 1, 2015 12:24 PM
guitarman376
Sep 30, 2015 05:54 PM
RCS02v6
Sep 29, 2015 01:46 PM
