HELP WITH LED FLOOR LIGHT WIRING
Old Jul 18, 2005 | 07:31 PM
dbryant's Avatar
dbryant
Default HELP WITH LED FLOOR LIGHT WIRING
I dont think i want to make a hole and connect the lights to the battery how do i go about wiring them to the fusebox? i need step by step full out, thanks i have a 94 mustang v6
Old Jul 18, 2005 | 10:34 PM
fordguy17's Avatar
fordguy17
Default RE: HELP WITH LED FLOOR LIGHT WIRING
they make little connectors that you can plug into the fuse panel and than plug the fuse over the connector. make sure you hook it up to a fuse that only receives power when the igniton is on.
Old Jul 19, 2005 | 04:04 PM
99saleen351r's Avatar
99saleen351r
Get a test light, Then turn the key on and search the fuse box till you find one spot with power.Next shut the key off and see if it stilll is powered if it is get the wire your using and put a spade connecter on the end and plug it in were the power is.Very easy
Old Jul 20, 2005 | 12:47 PM
pete1665's Avatar
pete1665
get a haynes manual. They have wiring diagrams in the back. Then find a wire that is hot with the key off(probably the dome light circuit) and tap into that.
Old Jul 20, 2005 | 11:13 PM
Kidrosey's Avatar
Kidrosey
You could also wire it to the cigarette lighter. They are always on in Fords.
Nurdyguy
Jan 20, 2025 04:38 PM
Ford_Dude
Sep 15, 2015 03:25 PM
unit91
Sep 15, 2015 09:53 AM
cbird1177711
Sep 3, 2015 08:43 PM
cbird1177711
Sep 2, 2015 08:51 PM
