S197 Head Unit Install
Old Dec 1, 2009 | 04:08 PM
JCON's Avatar
JCON
Default S197 Head Unit Install
I know with most after market H/U we need to put a 5V regulator in. I did that with my current Alpine.
http://www.bestbuy.com/site/Alpine+-...=1199494645981
This H/U however has 4V pre-outs, any idea how this would affect the sound if I got this one and installed it?
Old Dec 2, 2009 | 08:46 PM
pentavolvo's Avatar
pentavolvo
5 volt regulator and preout voltage are not related to eachother
Old Dec 2, 2009 | 09:58 PM
JCON's Avatar
JCON
I thought I put the 5V reg on the preout to keep it from popping.
I know i did put it on something and it stopped the pop
Old Dec 2, 2009 | 10:47 PM
Iskwezm's Avatar
Iskwezm
You can put a 1k ohm resistor on the amp turn on
Old Dec 3, 2009 | 12:02 AM
JCON's Avatar
JCON
do i have to? Correct me if I'm wrong, I want the head unit preout voltage to match the amp input voltage right? So if the head unit preout is 4V do I need to do anything or is it ok being lower?
Old Dec 3, 2009 | 02:58 PM
Iskwezm's Avatar
Iskwezm
The higher the pre out voltage the more efficient/better sound you will have. The gain on the amp is adjustable to match the headunit.
Old Dec 3, 2009 | 06:52 PM
pentavolvo's Avatar
pentavolvo
you are confusing the preamp output voltage and the voltage required on the remote turn on wire for the oem amp. They are 100% different things. 5 volt regulator on the turn on line is all that is required
Old Dec 3, 2009 | 10:01 PM
JCON's Avatar
JCON
thanks for clearing that up.
Old Dec 5, 2009 | 07:20 PM
Iskwezm's Avatar
Iskwezm
We have noticed that the 5V output Ford uses is not enough to turn on some amps.
Old Dec 6, 2009 | 07:47 PM
pentavolvo's Avatar
pentavolvo
how does that apply?
