Hi/Low Impedance Adapter Help
Old Dec 4, 2009 | 10:40 AM
freefallin98's Avatar
freefallin98
Default Hi/Low Impedance Adapter Help
I installed one on my 2000 Mustang yesterday. I drilled it up behind the amp rack and spliced, or at least attempted to splice into the data cable that sits in that area. I unplugged it from the clip once I had the unit drilled in and I figured out what colors were negative and what colors were positive.
I spliced the negatives into the negatives and positives into the positives. Everything else is ran and ready to role, but for some reason the sub was getting no power. I am nearly certain that this has to be my problem, or something having to do with either how I wired it or what you have it.
Please help me figure it out.
Old Dec 4, 2009 | 11:08 AM
stanged's Avatar
stanged
Does this help?
Old Dec 4, 2009 | 05:13 PM
HypromanGT's Avatar
HypromanGT
What make/model unit are you using?
Old Dec 5, 2009 | 01:52 AM
freefallin98
No, that does not help. I had it a couple negs and positives flip flopped. But I re-wired the entire thing and for some reason I getting nothing. It;s super annoying, belittling and weird because I have the power cable ran, the remote ran, speaker cable, rcas, etc. The ground is ran as well but I noticed that it's kind of touching some rubber stuff where the nut used to be. Would this affect anything? I do not even think the amp is getting a signal.
Old Dec 5, 2009 | 07:15 PM
Iskwezm's Avatar
Iskwezm
Use a tone generator or use MP3 or ipod to rca cord to your amp to see if it gets a signal that way.Is the amp turning on?
Old Dec 6, 2009 | 01:16 AM
freefallin98
Blown power wire fuse. Need tp run thicker gauge. I am only running 12 g to my amp and sub. I need 4 to be safe.
Old Dec 7, 2009 | 11:44 AM
ttocs's Avatar
ttocs
we would need a list of the equipment to tell you if you need thicker wires or not. Did you make any sparks on the installation that could have blows a fuse?
dudeguy421
Sep 24, 2015 11:16 AM
Sminemann
Sep 17, 2015 09:24 AM
Ford_Dude
Sep 15, 2015 03:25 PM
Doogie65
Sep 6, 2015 02:55 PM
