wiring battery
Old Jul 20, 2005 | 05:35 PM
dbryant's Avatar
dbryant
Default wiring battery
can you connect an amp wire and an led light wire together on the battery at the same time if there touchin each other? or do u need some kind of spacer when u connect the 2? PLUS will i need anything to connect between the battery and the led lights to prevent overload or something like an amp i do hjave a switch for led
Old Jul 20, 2005 | 08:28 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Default RE: wiring battery
ORIGINAL: dbryant
You mean neon lights? It's best to have a power distributor on the battery like the one below (2nd one on the page) it makes for a much cleaner install and an easier fix if there's ever a problem.
http://www.monstercable.com/caraudio...%20Connections
Most auto install shops will carry them. You probably don't need one as pretty as the one above. If you notice, you have a total of three outlets, one could be to fuse block for amps, one for battery, and one for...LEDS/Neon.
Old Jul 21, 2005 | 01:45 PM
99saleen351r's Avatar
99saleen351r
You dont need anything if you dont want to sppend the money.Just put a ring connector on them and put them on the bolt toghter, it wont hurt anything
BOB ROME
Jul 26, 2023 01:54 PM
jwog666
Dec 27, 2021 08:09 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
Dathan
Oct 5, 2015 05:52 AM
logan409
Sep 26, 2015 07:43 PM
