Shaker 500 Radio
Old Dec 28, 2009 | 02:00 PM
maxshuty's Avatar
maxshuty
Default Shaker 500 Radio
I installed the shaker500 a long time ago in my car because I wanted the 6 disc cd changer - and it has been a big help for me. However when I installed it I did not connect the radio cable to the port in the back of the shaker500. The reason was because I couldn't figure out how to make it fit! I think they were two different sizes or something...? Does anyone know why this is and if there is a way around this? I never use the radio but this Christmas I got an iTrip and that requires the radio and I'd love to use that now. If I take it to an audio place is there some way they could get it connected for me without me having to sacrifice the Shaker500 (ie an adapter of some sort)? Or am I forced to install my old single-cd unit back into the car?
I'm in an 07 Mustang, not sure what year the Shaker500 is from though... I have never experienced any problems with the shaker.
Old Dec 29, 2009 | 01:42 AM
HypromanGT's Avatar
HypromanGT
What exactly do you mean by the "radio cable"? Are you referring to the antenna plug? It's the round co-axial looking cable?
I'm not sure, but I would think that there should be absolutely no difference between the two systems regarding this cable hookup. It should just snap into the back of the unit.
Old Dec 29, 2009 | 04:51 PM
pentavolvo's Avatar
pentavolvo
your radio is most likely from an 05
you need a metra 40-cr10 (yes its a chryler antenna adapter)
most stores will stock a 40-cr20 meaning you need to order this online most likely then just plug it in
Old Dec 29, 2009 | 10:02 PM
maxshuty's Avatar
maxshuty
(Sorry I'm an electronics dummy)
I did the install last summer by myself the one in the bottom left corner (circle port) is the one that wouldn't connect:
So pentavolvo what I need is a 40-CR10 to get my antenna cable to connect to the Shaker500 unit?
Old Dec 30, 2009 | 02:50 PM
pentavolvo's Avatar
pentavolvo
yup as i said 40-cr10
http://cgi.ebay.com/CRAB-40-CR10-JEE...item518ca0044e
kevsgt
Oct 9, 2015 10:12 PM
breaking
Oct 2, 2015 01:27 PM
nmra1965
Other Professional Racing
Sep 26, 2015 10:46 AM
unit91
Sep 15, 2015 09:53 AM
cbird1177711
Sep 3, 2015 08:43 PM
