Has anyone replaced their front turn signal 3157 bulbs with LEDs? I believe you need to modify the turn signal flasher, since it sees a different load than with a filament bulb. Does anyone here have a working setup? I have HID headlights and foglights that make my turn signals look dim, so I'm looking to go brighter white.
I found that the relay is cheaper than buying a load resistor for each light and easier to install... plus it doesn't heat up and waste energy. But I guess it just depends on where you buy it from.
