Interior lights (LEDs) under the dask
Old Jan 17, 2010 | 12:45 PM
Matt's 95 Stang's Avatar
Matt's 95 Stang
Resident Ginger
Default Interior lights (LEDs) under the dask
So I wanted to add some interior lights; not to have on while driving or anything like that just to have if I need light around my feet. They require a 12V plug in so I need to know where I could wire the positive under the dash. Anyone done this before? Have a better set they know work great?
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
Thanks,
Matthew
Old Jan 17, 2010 | 05:57 PM
Iskwezm's Avatar
Iskwezm
you could wire them to the illumination wire on the headlight switch so they only come on at night or wire them to a switch so you can use them only when you want to.Look for a 12V switched wire in the fuse box and use a fuse tap wired to a toggle switch.
Old Jan 28, 2010 | 10:13 PM
Sho_No_Go's Avatar
Sho_No_Go
I would wire them to a switch from Autozone or PepBoys or whatever store it is you have around you. I think you can even get the switches from Wal-mart. Then I would tap into the 12V wire for the lighter or something like that. Preferably something that only has power when the ignition is turned on. Then find a good ground connection. Then you can turn the lights on and off when you want to.
Old Jan 29, 2010 | 04:02 PM
tdcalhoun89's Avatar
tdcalhoun89
good idea, those lights look a little wild, they'll probably get annoying after a while or when the cop pulls you over, your not gonna want all those lights going on
McLeary
Mar 14, 2016 07:50 PM
andrew1969
16
Jan 8, 2016 02:48 PM
Seanam
Oct 4, 2015 10:15 AM
accarter
Sep 21, 2015 11:56 PM
Colin Ringle
Sep 15, 2015 09:27 PM
