Need Help setting my amp
Old Jan 30, 2010 | 12:24 PM
PennState's Avatar
PennState
Default Need Help setting my amp
Hey guys so I got my new amp and sub.
It's an ALPINE TYPE R 4OHM SUB WIRED AT 2OHM
http://signature.crutchfield.com/s_5...e+type+r&ssi=0
and this is the amp
http://www.sonicelectronix.com/item_...KAC-8104D.html
What are good controls to set the amp at? I listen to hiphop and techno a lot. Im talking about
The bass boost? LPF? and Input Sensitivity?
Thanks for the help!
Old Jan 30, 2010 | 12:57 PM
pentavolvo's Avatar
pentavolvo
bass boost up a hair maybe 1/4 way
LPF at 80hz
Gain/sensitivity where you see fit, more isnt always better, dont drive it into clipping
Old Jan 30, 2010 | 05:05 PM
tdcalhoun89's Avatar
tdcalhoun89
just change the settings and figure out what sounds best to you
Old Feb 1, 2010 | 02:51 PM
PennState's Avatar
PennState
I tried everything you guys said but it still doesnt seem right, I believe its something from the radio. What should I have these settings set at? See the thing is i had my amp installed a while back when i had the shaker radio, so they used a line out convertor for the amp. So i cant use the sub woofer output to control the subs. Here is what I have now:
Old Feb 1, 2010 | 11:40 PM
pentavolvo's Avatar
pentavolvo
turn the highpass filter off thats ur problem, u really need to get rid of the LOC and run rcas directly to your headunit
Old Feb 2, 2010 | 11:07 PM
tdcalhoun89
manual?
I know, I know, I know... sometimes you just gotta actually read it
Old Feb 4, 2010 | 04:27 PM
PennState's Avatar
PennState
ok so now my sub is directly connected to the radio. I can control the sub from the headunit.
So now I have the EQ set to powerful, should i turn both HPF and Loudness off on the headunit?
and then keep the amp at 80hz and now mess around with the gain?
Old Feb 5, 2010 | 02:39 AM
PennState's Avatar
PennState
also how would i connect my shakers now?
GimpyHSHS
19
Dec 19, 2023 01:12 PM
TCStangerv6
Oct 11, 2015 05:57 PM
mustangheaven
Oct 7, 2015 10:23 AM
breaking
Oct 2, 2015 01:27 PM
guitarman376
Sep 30, 2015 05:54 PM
