Amp Wiring
Old May 28, 2010 | 01:32 AM
Cante's Avatar
Cante
Default Amp Wiring
I just installed a head unit in my 1999 Mustang (premium sound), and I had to crimp the remote wire from my head unit to the remote wire from my car's optional amplifier for my speakers to work. I have a Rockford Fosgate amplifier coming in to power a subwoofer, and I know I need to wire the remote wire for this one too. What do I crimp it to?
By the way, if anything sounds wrong it's because I don't 100% understand this.
Old May 28, 2010 | 07:24 AM
2005Redfire6's Avatar
2005Redfire6
Im not %100 sure, but my buddy works for Best buy and hes an installer so he did mine. I want to say he spliced it into a wire from the ignition, not sure though.
Old May 28, 2010 | 08:37 AM
MOOK3456's Avatar
MOOK3456
Run the new amps remote to the same remote lead. It's ok to have 2 on it. If there is a terminal on the factory amp for the remote, just hook it up there. If it runs into the amp internally, splice it in where you connected from your HU. A good way to secure it, being a 3 way connection is a wire cap and electrical tape over and around it a few times if you're not into soldering it. (it tends to come loose when its hot so use plenty) Anytime I had to use elec tape, personally I use some duct tape over it. That usually keeps it together well.
The remote just sends a low voltage signal to turn it on so don't worry about it being too much load. It's basically just a switch.
Old May 28, 2010 | 09:28 PM
Cante's Avatar
Cante
I used a Scosche harness to wire the factory amp to my HU's wire, so would I just tape the 3 wires together? Or am I going to have to dig and find the factory amp?
Old May 28, 2010 | 10:03 PM
MOOK3456's Avatar
MOOK3456
No need to dig for it, you can just twist it into the same spot where you hooked up the lead from the harness/HU.
Old May 29, 2010 | 01:02 AM
Cante's Avatar
Cante
Thank you!
jwog666
Dec 27, 2021 08:09 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Dathan
Oct 5, 2015 05:52 AM
breaking
Oct 2, 2015 01:27 PM
