is 3 amps too much?
Old Jul 29, 2010 | 01:37 AM
stanged's Avatar
stanged
Default oldsch00lf00l...
Good to see that you do understand the problem. I did some power amplifier design for both audio and electron beam deflection over 30 years ago. For audio the more troubling problem was crossover distortion as the output switched from the plus driver to the negative driver, most noticeable as distortion at low volume levels. That is why at that time we needed to have both drivers conducting (even when at a quiescent state) to minimize the crossover distortion. This is what contributed to lower efficiencies at low power levels and with the power transistors then available, could lead to thermal runaway. Negative feedback helped reduce the distortion but was always susceptible to becoming unstable depending upon the amplifiers load. I am quite sure amplifier design has greatly improved since those days.
Old Jul 12, 2011 | 09:21 AM
Bmr4life's Avatar
Bmr4life
Originally Posted by AudioNutz
You're very young, and wouldn't know who I am, so I'll take it easy on you. You've defined a "Storage Tank" and an "Energy Supply", yet I'm talking about a "Source".
You can start your car with a battery, but no alternator. You cannot start your car with an alternator, but no battery. The battery is the source. The alternator just puts back what energy has been used.
This is also a very untrue statement, If your car isn't running, can you power anything with the alternator? You can certainly power everything with a battery...
...but I digress for now...
You can run a car with an alternator, but no battery. Same can be said the other way around, but it won't last long. The alternator is what powers your stereo, once the alternator is maxed out, the battery gives a hand.
Old Jul 13, 2011 | 11:55 PM
d.girardi's Avatar
d.girardi
im running 2000 watts amp to two l5's and a 1200 watt amp to my memphis speakers with a 20 farad cap, no dimming
breaking
Oct 2, 2015 01:27 PM
vbonina
Sep 22, 2015 08:31 AM
daytooday
Sep 20, 2015 10:55 AM
Art161
Sep 9, 2015 10:33 AM
cbird1177711
Sep 3, 2015 08:43 PM
