Best line level converter?
Old Nov 20, 2010 | 09:25 AM
Blakerall90's Avatar
Blakerall90
Default Best line level converter?
Hey i got a kicker 500 watt amp and a boston acoustic g2 12inch sub. and i was wondering what would be the best line level converter to hook up to my rear speakers...
Old Nov 20, 2010 | 10:24 AM
RHuckster's Avatar
RHuckster
I've used Audiocontrol line level converters in the past. I have 1 somewhere in my stereo stuff stacked away in totes. The best thing with them is that they have a power on output for the amp(soft on) so when it senses power to your speakers it turns on your amp(s)
http://www.audiocontrol.com/t34/1761...tegration.html
Rick
Old Nov 20, 2010 | 04:03 PM
Iskwezm's Avatar
Iskwezm
If you tapping into a factory amplified speaker make sure to use a high power LOC.Most are 35 watts and the better ones handle 50 watts.We have seen them melt from the wrong application
Old Dec 11, 2010 | 08:55 AM
msmith's Avatar
msmith
JL Audio Cleansweep CL441dsp... it does more than just convert to line level. It also corrects the OEM Equalization programmed into the head unit, turns your system on/off via signal sensing and also provides a clean Aux Input for additional sources. Not the cheapest solution... about $300.00, but you asked for the best.
GPR
Dec 16, 2015 12:21 PM
Oct 7, 2015 07:02 PM
LivingInThePast
Sep 16, 2015 12:20 PM
rksnow1
Sep 14, 2015 08:46 PM
Sep 8, 2015 11:50 AM
