trying to install voltage regulator
Old Jan 5, 2011 | 04:54 PM
tigercrazy718's Avatar
tigercrazy718
Default trying to install voltage regulator
so im trying to figure out the exact set up for the wiring on the 4200
i have all the colors matched up and i understand how to do the bypass, but i have a couple questions:
1.since both the regulator to stop the popping of the subs and the bypass relay use the blue and white system remote control wire, i just split it into two wires im assuming
2. im pretty sure i read this somewhere but the mute wire is only used if i have the bluetooth thing
3. where did yall ground the unit? any particular place?
4. i bought the extended ipod control cable seen here:
http://www.amazon.com/gp/product/B00...ef=oss_product
so if i use this, this pretty much stops me from watching dvds on a flash drive since it takes up the only usb slot right? or is there some kind of work around?
if you cant understand what im talking about in any of the questions just let me know and ill try and draw a diagram to explain it better.
thanks!
Old Jan 5, 2011 | 05:37 PM
tigercrazy718
ok and one more question
the solid blue wire on the metra harness i guess i just leave alone since there doesnt appear to be a corresponding color
Old Jan 5, 2011 | 06:58 PM
pentavolvo's Avatar
pentavolvo
you will not use the blue wire
split blue/white between relay and the voltage regulator
use ground in harness or go to a metal bolt in the dash
as far as flash drive/ipod run the usb to a spot where u can unplug the ipod cable and plug a flash drive in if u desire that option
Old Jan 5, 2011 | 09:28 PM
tigercrazy718
ok thanks man!
one more question this is just to double check my work: i connect the blue/white from the metra to the blue/white to the pioneer correct? just making sure just bc ive already done so much to that wire lol
Old Jan 6, 2011 | 09:24 AM
wayne613's Avatar
wayne613
What it actually is should be on the plastic packaging for the harness (color chart). They'll usually match up, but not always.
The 4200 should also have a color = chart somewhere, usually stamped on the top of the unit. Solid blue for the metra harness is for a remote antenna. Not used.
TfcCDR
Sep 14, 2015 12:08 PM
wilsonro
4 Cylinder NA and Turbo
Sep 11, 2015 07:13 AM
zanemoseley
Sep 6, 2015 12:58 PM
cbird1177711
Sep 3, 2015 08:43 PM
cbird1177711
Sep 2, 2015 08:51 PM
