Installed new head unit, only 2 speakers work
Old Aug 25, 2005 | 03:34 AM
nyjets10's Avatar
nyjets10
Default Installed new head unit, only 2 speakers work
I installed my new head unit in my 02 GT yesterday and upon testing it, only 2 speakers work. They are the 2 that are on the door by the side view mirrors an I think they are the high frequency speakers. I used the schosche wiring harness specific for the mach system but it seemed a bit bootleg when i was wiring. I'm almost sure all of my connections are correct so i'm thinking i dont have the right harness. From reading this forum, ive noticed that a lot of people seem to have problems with the mach system and that it is very hard to wire. Does anyone know if i need this in addition to the standard wiring harness: http://www.cardomain.com/item/PERSVHFD3
By reading the description it definitely seems like this is what the missing link is. Here is my head unit and the wiring harness i have it running through right now:
http://www.cardomain.com/item/PIODEH2700
http://www.cardomain.com/item/SCOFDK9B
Any advice would be awesome. thank you
Old Aug 26, 2005 | 11:47 AM
nyjets10's Avatar
nyjets10
Default RE: Installed new head unit, only 2 speakers work
bump
Old Aug 26, 2005 | 10:49 PM
Kidrosey's Avatar
Kidrosey
I had the same problems with the adapter when I installed my HU. I noticed that the connections between the original harness and the adapter harness weren't tight so they weren't getting a good connection. See if that might be your problem.
Old Aug 26, 2005 | 11:31 PM
nyjets10's Avatar
nyjets10
Hm, ok I'll give that a try. Keep in mind I don't have the adapter yet I only have the basic wiring harness. I did my connections with electrical tape which I noticed kept sliding off and it seemed to suck. I also tried the little plastic connectors with the metal on the inside but they slid too. Any good ideas?
Old Aug 27, 2005 | 11:05 AM
JayCe's Avatar
JayCe
For the '02, this wiring harness should intergrate the headunit with the factory speakers and amps perfectly. http://www.partsexpress.com/pe/pshow...number=265-790
Although it says 2000-2001, a few that have tried it with the '02 have had success.
If that doesn't work for some reason though, this should be the harness for you.
http://www.crutchfield.com/S-4V7HOoc...00&I=120705700
Old Aug 27, 2005 | 11:46 PM
nyjets10's Avatar
nyjets10
Update: I soldered the connections this time since they were falling off and now the 4 rear speakers (2 on either side) work. So i have the front top 2 (left/right) by the side view mirrors and all rear speakers working but not the 2 front lower speakers. On my wiring harness, I did not need to use one of the 3 connections since it was blue or blue/white (i forget) and brown and i didnt need either of them. For the front right and front left I think there were 2 wires coming from the amp to the CD player for each of them as opposed to 1 for all the others. I wired both of these 2 coming from the amp to the 1 coming from the CD player... Seeing as the 2 front lower speakers are the ones not working, did I wire that part wrong?
Thanks
Old Aug 29, 2005 | 08:59 PM
nyjets10's Avatar
nyjets10
bump.
about the 2 speakers not working
Soldier GT
Aug 12, 2015 03:46 PM
dseg
AmericanMuscle.com
Aug 10, 2015 03:29 PM
pjrolvrz
Aug 10, 2015 02:10 PM
pjrolvrz
Aug 10, 2015 01:39 PM
dragman72
Aug 9, 2015 12:54 AM
