Seperate power hook up
Old Aug 25, 2005 | 02:54 PM
Zincpony's Avatar
Zincpony
Default Seperate power hook up
I wana hook up my system to its own battery source so that it doesnt drain from my battery. what do i need to purchase for this. im not gonna need another 12V car battery am I?
Old Aug 25, 2005 | 10:51 PM
bonesninja's Avatar
bonesninja
Default RE: Seperate power hook up
ORIGINAL: Zincpony
your stereo doesn't need a second battery, you need a higher output alternator to truly take care of any voltage drops its getting. but in reality you can get away with just changing out your stock battery for a yellow top optima deep cycle. your stereo should only be draining your battery if you play the music loud while the engine isn't running
Old Aug 26, 2005 | 03:37 PM
Zincpony's Avatar
Zincpony
but like as im driving whenever my subs hit i can see my headlights, the interior gauge lights, even the head unit dim when ever the bass is pumpin
Old Aug 26, 2005 | 06:19 PM
bonesninja's Avatar
bonesninja
ORIGINAL: Zincpony
then you have some electrical system issues-what you start with is a deep cycle battery as mentioned and a big 3 wiring upgrade. you can go to www.caraudio.com and search for big three and you can find a walkthrough on how to do it yourself. The best fix tho is to upgrade your alternator to a higher output one. a second battery will end up adding more of a strain to an already struggling elec. system because then your poor alternator has to charge 2 batteries instead of 1.
Old Aug 26, 2005 | 06:23 PM
97BlackStang's Avatar
97BlackStang
i need a new alternator, well want one and i cant seem to find one. Can someone post a link to some good alternators?
Old Aug 26, 2005 | 09:39 PM
bonesninja's Avatar
bonesninja
www.ohiogen.com
www.excessiveamperage.com
Old Aug 26, 2005 | 10:53 PM
Kidrosey's Avatar
Kidrosey
People tend to overlook capacitors. Get a 1 microfarad cap and you should have plenty of charge to keep from draining your battery.
Old Aug 26, 2005 | 11:15 PM
Zincpony's Avatar
Zincpony
my alternator is in practically great shape. I tested the battery reading before and after and its in great shape. reading exactly whats it suppose to be.
Old Aug 26, 2005 | 11:53 PM
bonesninja's Avatar
bonesninja
if your getting enough voltage drops to dim all your lights---your well on your way to killing your alt and battery. trust me--i've been doing this for about 16 years nows. if you want the real proof -- measure your voltage while your bass is hitting. a cap may help slightly but is no help at all to a well overstressed electrical system.
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
88 orangepeel notch
Oct 5, 2015 09:03 AM
KingRando
Oct 2, 2015 08:06 AM
DtRockstar1
Mustang Videos
Sep 27, 2015 07:46 PM
Sep 25, 2015 06:58 PM
