Tweeter Pods, pretty easy mod
Old Mar 24, 2011 | 12:03 PM
awsomeaussies206's Avatar
awsomeaussies206
Default Tweeter Pods, pretty easy mod
I just wanted to share my experience. I made some tweeter pods where my mirror control was located. It was fairly easy. For smaller projects fiberglass isn't necessary. Instead you can use a cotton rag or an old cotton t-shirt and some thin superglue.
First I mounted the tweeter with some super glue. You could also make a wood mount if you want to make the tweeter removeable, but I was in a hurry so I didn't take the extra time to do that.
Next take a cotton rag/t-shirt and drape it over the top of everything. Next take some duct tape and stretch the shirt and tape it to the back of your panel. So now the shirt is nice and tight, while your tweeter is under the shirt also.
Now take your super glue. I used the locktight superglue that I got at Home Depot. Just make sure whatever superglue you use, it's really thin. You could also go to the hobby store and get ca glue. Anyways pore the superglue all over the shirt. It will take a little while because it doesn't come out very fast. The shirt will actually start to smoke a bit, but I think it's the reaction from the superglue. The shirt will start to harden, just make sure you don't get near your tweeter grill!!
Let it set for a while until it drys, it won't take very long. Next you can cut off the extra fabric and tape on the back side. You can also cut off the fabric over the tweeter. Now you'll probably want to put some tape over the tweeter only because we don't want to get any body filler on it.
Take your body filler/bondo and apply a small coat over the harden fabric. You don't need much because you should have a pretty nice looking piece already. This will just make sure everything is nice and smooth. Let it dry then sand.
And that's it! You could either wrap it like I did or you could paint it. Either way should turn out great!
Here's what my finished tweeter pod turned out like....
I wish I took pictures along the way, but I didn't expect them to turn out as good as they did. lol It was my first time making anything like this and it was actually super easy. The longest part was just sanding them.
For the driver side tweeter you'll have to move the mirror control, which I haven't done yet, but I'm just going to move it to my door.
Old Mar 24, 2011 | 10:05 PM
charliebrown266's Avatar
charliebrown266
Look's great man,very nice job!
Old Mar 25, 2011 | 12:25 PM
newfiveoh's Avatar
newfiveoh
Very nice. I'd like to see how you incorporate the mirror controls into the door.
Old Mar 28, 2011 | 11:11 AM
awsomeaussies206
I'll get to that soon, but it shouldn't be to hard I just need to extend some wires.
Old Mar 28, 2011 | 02:06 PM
HT's Avatar
HT
Can you get a picture from further away with the door closed?
I had no idea that the series of steps you listed would possibly turn out like that. Very nice.
Old Mar 29, 2011 | 08:02 PM
oldsch00lf00l's Avatar
oldsch00lf00l
A buddy of mine sent me this photo when I was in the process of trying to figure out what I was going to do with my vehicle:
Old Mar 30, 2011 | 04:05 AM
ttocs's Avatar
ttocs
just as an fyi, the smoke is because it generates heat as it cures(just like fiberglass). It can get hot enough to catch fire and pretty sure the smoke is toxic since you are messing with CA...
It does look good but I will wonder how long it will really last. CA doesn't bend/give at all and tends to start cracking/chipping if exposed to vibrations like that one will with the doors opening and closing.
McLeary
Mar 14, 2016 07:50 PM
firecoyote
Sep 27, 2015 02:37 PM
Roush05
Sep 10, 2015 12:23 PM
robjh22
Suspension
Sep 8, 2015 12:47 PM
TimeLord101
Sep 4, 2015 09:27 AM
