Last edit by: IB Advertising
Browse all: Ford Mustang Interior Guides
- Ford Mustang V6 2005-2014: How to Install Backup Camera
Step by step instructions for do-it-yourself repairs.
Backup camera
I would like to add a backup camera to my Pioneer deh-p4200dvd head unit. Obviously the unit is prewired for this, but I'm not sure what I need to get it working.
Would a camera such as this work?
http://cgi.ebay.com/Night-Vision-Car...item4154841809
And then I would just have to hook up the reverse wire from the Pioneer radio harness so it automatically switches to it when I am in reverse?
You may wish to view this as well. A complete write-up on his backup camera that he used. I mention this, as it looks a ****-ton better than most of the usual license plate mounted ones. Full exchange here.
Assuming you have the PAC c2r-frd1, then itīs just the green (reverse light) to the Pioneerīs Violet/White lead. And of course giving the camera itself a 12v source back there. Switched 12v that is, you may need to run a line. 60mA may not seem like much, but...
The PAC unit interprets the can-bus signal for you up there to make things easier. Reverse lamp functioning here. So, likely going to need to tap at the SJB on the white/yellow lead, or the DG/OG one (not sure what DG means color code wise offhand).
Hereīs the12volt.comīs (have to register to view threads)entry on it:
Reverse Light-----white/yellow----- + PKP or SJB, gry 52 pin plug, pin 13
But, Iīd certainly make sure in either case to check it out with the e-brake up manually with a DMM of course.
