2004 gt
Old Aug 28, 2005 | 03:40 AM
cncmxz600's Avatar
cncmxz600
Default 2004 gt
i have a 2004 gt and no mach system, is there going to be any troubles trying to install a aftermarket h/u that i should know about, and if its just a single din h/u what will i need to make it fit and look good.?
Old Aug 28, 2005 | 07:12 PM
v8musclecobra's Avatar
v8musclecobra
Default RE: 2004 gt
might be cool to fiberglass on your center dash piece to make the new hu fit in an exact hole. so there is no gap between the headunit and the center dash trim, and it doesn't look aftermarket.
Old Aug 29, 2005 | 12:50 AM
mattwilliams's Avatar
mattwilliams
Default RE: 2004 gt
installing an aftermarked h/u is extremley easy. Just go to any place that sells automotive audio equipment. Buy an installation kit, and a wire harness. Pop off the plastic peice around your shifter, then the peice around your head unit. That will save you some trouble right there.
lincolnshibuya
Dec 8, 2015 04:37 PM
breaking
Oct 2, 2015 01:27 PM
zachary1988
Sep 4, 2015 03:04 PM
hookergt
Sep 4, 2015 06:57 AM
MustangHead91
Aug 16, 2015 03:20 PM
