Gutted mach sound system, tips
Old May 14, 2011 | 09:05 PM
Cinn's Avatar
Cinn
Lightbulb Gutted mach sound system, tips
JVC double din head unit
4 Rockford 6x8's
2 alpine type e 12's
2 kenwood 720 watt 4 channel amps later....
I have everything setup and I will never buy another rockford fosgate product aslong as I live. They wouldn't work right when wired soley to the head unit so I purchased and installed a second amp to run them off of and come to find out 2 of the 4 speakers were faulty (one was actually broke as in the tweeter and wires were cracked apart and one was just messed up). I have everything fine now but I have a question again.
I am now just running vocals off the front two rockford speakers with a little bit of bass and it sounds plenty fine so instead of buying two more 6x8s I was gonna just run 2 stock tweeters in the back and run them off of the amp aswell that way I can filter the lows for those two tweeters with no problem.
They will get 60 rms each tweeter will this be a problem? What is the ohm impedance (spell check?) of the stock tweeters, cause aren't the ohm of the stock mach speakers combined with tweeters 4 ohm? If so would that make the tweeter by itself 8 ohm?
Any tips on how I should go about this? As of now since I returned the 2 faulty 6x8s I only have as follows setup: 2 6x8's running off of an 1 amp in the trunk with 2 spare channels open on that amp. 2 12" subs running off a seperate amp. No speakers going to the head unit. Still have all 4 stock tweeters. What would you do?
Old May 15, 2011 | 08:33 AM
Schweino's Avatar
Schweino
I am so confused on what exactly your wanting to replace, and is one of those Kenwood's powering your inside sound? Please respond Muahaha.
BUT, IF I was you, I would replace ALL those RF speakers and start over. Sell em on craigslist if you have too.
Old May 15, 2011 | 08:34 AM
Schweino's Avatar
Schweino
By the way, RF does amps, not speakers RF makes GREAT amps.
Old May 15, 2011 | 10:56 AM
ttocs's Avatar
ttocs
rf makes amps speakers and they even made a head unit a while back. Speakers are normally pretty good although if you were trying to get them to work with the mach system then there was your problem. What amps are you running, you never mention the brands/models.
60 watts will probably smoke the stock tweeters unless you are carefull. The location is actually horrible for imaging as you move one speaker 2 ft closer to your ears while all the others stay the same. I use them for bluetooth but for the stereo they do not play.
Old May 15, 2011 | 10:59 AM
Cinn's Avatar
Cinn
I paid 100 for 2 speakers so I am stuck with those, they aren't bad but after the rear 2 broke I know worry. So I will replace the front whenever they go out (which hopefully is a long time).
Yeah one kenwood is powering the 4 inside speakers (now only 2 inside so 2 free channels available) and the other kenwood is powering two subs in the trunk.
I can either buy some cheap or clearance 6x8s to replace in the rear or just wire up two of the old stock tweeters to run in the back.
Old May 15, 2011 | 11:02 AM
Cinn's Avatar
Cinn
Sorry they are the kenwood kac-8405, 2 of them. And I have already bypassed everything mach and gutted the mach.
Old May 15, 2011 | 11:13 AM
Cinn's Avatar
Cinn
I have two kenwood kac-8405 amps. One running inside speakers and one running two subs.
I have gutted the entire mach system none of it is there anymore except the door tweeters but they are disconnected and there for looks.
Old May 16, 2011 | 06:35 AM
Schweino's Avatar
Schweino
Okkk lets see what we got here
kenwood kac-8405 puts out 60w rms at 4 ohms, and 90w rms at 2 ohms...so theres your front speaker choices..Is your budget 100 or?
Old May 16, 2011 | 06:38 AM
Schweino's Avatar
Schweino
Oh, and by the way, Infinity Kappa 6x8's are 90w rms, 2 ohms On ebay they are 130 bucks. I have them in my front, and they are sweeet.
Old May 16, 2011 | 11:39 AM
ttocs's Avatar
ttocs
man I have never understood people love with infinity speakers as the tweeter in those are just too rich and make my ears want to bleed.
