94 GT Boot
Old Sep 9, 2005 | 11:06 PM
racerx3165's Avatar
racerx3165
Default 94 GT Boot
Ive seen one boot install in a mustang and it was a 96 cobra i beleive, has anyone seen any good pics of any Boots or really any good installs in a 94 GT. I am trying to use as little space as possible, and would like to have a good-great SQ car audio system. Plus i want to keep the weight down to a minimum for performance, so im trying to get rid of my 3 cu. ft. 3/4 in. MDF box.
Ty
RacerX
Old Sep 10, 2005 | 01:25 AM
v8musclecobra's Avatar
v8musclecobra
Default RE: 94 GT Boot
for sq, use a sealed enclosure with less internal volume. also use fiberglass for the weight. the cloth is way easier to work with then the mat but you need to extra layers. if you show me a pic of the trunk and a rough idea of what you want, ill draw something up for you and show you how to do it.
Old Sep 10, 2005 | 01:43 AM
racerx3165's Avatar
racerx3165
Cool ill get it tomarrow im going to try and push some cardboard up into the trunk to get a rough estimate of cu. ft. i can get per side and see exactly how much room its going to take to get my 05 C-12 4ohm Kickers their 1.25 i want them to have. I may start off with just one on one side and use the other side as the amp rack for a bit, and then work the other side.
Thank You for your help
Racer
ill get a pic tomarrow once its daylight out.
Old Sep 11, 2005 | 01:20 AM
v8musclecobra
ok sounds good. np man, just let me know when u get the pics up. incase i miss it my email is v8musclecobra@yahoo.com if you wanna let me know.
Old Sep 12, 2005 | 12:00 AM
racerx3165's Avatar
racerx3165
Well today before work i went out and took the carpeted panels out and did a little measuring and im not sure im going to make my 1.25 cu. ft. that i had wanted. the side i actually thought id have no problen with i removed the panel to see the Gas Tank Line behind it. So i may have to rething the whole boot idea. Would it be a good idea to use cardboard, and push it into the area to form a template then pull it out and lay fiber over that or how should i work around the gas tank line? I would like to leave 1/2 in. around the line if at all possible and im figuring that i can make my box about 1.0 cu.ft. The only thing i think im going to miss is the sound of rear firing subs, maybe when i finish it up ill angle them 10-15 deg. twords the back.
v8musclecobra ill work on the pics tomarrow after work
darkpony02
Mar 14, 2005 01:25 AM
Nl_Stang
Feb 19, 2005 04:33 AM
MustangtomodelA
Dec 16, 2004 05:25 PM
imported_admin
12
Dec 16, 2004 07:43 AM
xlitlbitx
Mar 4, 2004 10:26 PM
