installing alarm
be aware that you will be getting into the critical circuits of the cars ignition and that if/when done incorrectly/poorly will make for an expensive repair. Security is really not for the faint of heart or inexperienced honestly. I did my first alarm after I had been installing for 8 months and if it were not for my manager standing next to me telling me when to stop, I would not have attempted it. Either a cheap, or a badly installed alarm in the worst case scenario will strand you next to it somewhere wondering why it will not start.
The doorlocks are one of the more complex systems. It is a 5-wire reverse polarity which means you will have to be able to diagnose the correct wires(of the 5), the master/slave switch and then insert the relay corectly or you will blow out the door-lock circuit.
ttocs is correct i seen many car have problems with alarms and its always the installer
you have to be very careful you have to double check all your connection, and when doing the power locks always use a fuse before the relays just in case
PART COLOR LOCATION
12 VOLT CONSTANT YELLOW (+) IGNITION SWITCH HARNESS
STARTER RED/LIGHT BLUE (+) or WHITE/PINK (+) IGNITION SWITCH HARNESS
STARTER 2 N/A
IGNITION 1 RED/LIGHT GREEN (+) IGNITION SWITCH HARNESS
IGNITION 2 BLACK/LIGHT GREEN (+) IGNITION SWITCH HARNESS
IGNITION 3 N/A
ACCESSORY/HEATER BLOWER 1 GRAY/YELLOW (+) IGNITION SWITCH HARNESS
ACCESSORY/HEATER BLOWER 2 N/A
KEYSENSE N/A
PARKING LIGHTS ( - ) N/A
PARKING LIGHTS ( + ) BROWN (+) @ HEADLIGHT SWITCH or in DRIVERS KICK PANEL
POWER LOCK PINK/YELLOW (5 Wire Reverse Polarity) IN EITHER KICK PANEL
POWER UNLOCK PINK/LIGHT GREEN (5 Wire Reverse Polarity) IN EITHER KICK PANEL
DOOR TRIGGER BLACK/LIGHT BLUE (+) IN DRIVERS KICK PANEL at DOOR PIN SWITCH
DOMELIGHT SUPERVISION USE DOOR TRIGGER, Requires Part #R30-H Relay
TRUNK RELEASE PURPLE/YELLOW (+), Requires Part #R30-H Relay @ TRUNK RELEASE SWITCH
HORN YELLOW/LIGHT GREEN (-) @ STEERING COLUMN HARNESS
TACH TAN/YELLOW @ IGNITON COIL
BRAKE RED/LIGHT GREEN (+) @ SWITCH ABOVE BRAKE PEDAL
read this before you take the vehicle apart and do the installation
http://www.commandocaralarms.com/inf..._car_alarm.asp
PART COLOR LOCATION
STARTER 2 N/A
IGNITION 3 N/A
KEYSENSE N/A
Like the configuration above, the switch, when moved in either direction, applies both power and ground directly to motor legs without the use of any relays. Except, at the switch in this case, both motor legs rest at ground . Therefore it is only necessary to change the polarity of one motor leg to lock or unlock the vehicle.
http://k.b5z.net/i/u/6000490/i/pdf_d..._POL_DLCKS.pdf
Sep 10, 2015 08:39 PM
