Speaker question, is it blown?
Old Mar 12, 2012 | 11:23 AM
Shampue's Avatar
Shampue
Default Speaker question, is it blown?
My drivers door lower speaker (mach 460) sounds like it has a plastic bag covering it and vibrating. You know how someones trunk lid buzzes with a sub? My door speaker sounds like that, but only at medium to low volume. At higher volumes the buzzing goes away.
Is this speaker in need of replacement or do you think its something in the door panel making the noise? I thought if the speaker was blown then the buzzing would get worse at higher volume, but its the opposite.
thanks
Old Mar 12, 2012 | 02:28 PM
ttocs's Avatar
ttocs
maybe
Old Mar 15, 2012 | 05:07 PM
Chromeshadow's Avatar
Chromeshadow
There are a couple of ways to test the speaker, the simplest is to try another speaker... even one from a home stereo should work at moderate volumes. You could also run 2 wires from your door speaker to one of the rear speakers to see how it sounds...you need to disconnect the rear speaker first.
Dathan
Oct 5, 2015 05:52 AM
jrrhd73must
Oct 2, 2015 09:17 PM
breaking
Oct 2, 2015 01:27 PM
Sixer4Life
Sep 29, 2015 07:03 PM
treesloth
Sep 28, 2015 07:03 AM
