radar dectectors
Old Sep 17, 2005 | 09:57 PM
crmstang's Avatar
crmstang
Default radar dectectors
i plug my radar dector into the cig lighter. and i was wondering if i leave the plug in the plug will that drain my battery? i got the radar dectector at a garge sale for 75c. its a beltronics 715i. and also what does pv stand for?
Old Sep 17, 2005 | 11:06 PM
marlinmon07's Avatar
marlinmon07
Default RE: radar dectectors
if you can turn your radar detector off and leave it plugged in, it will not drain the battery. otherwise unplug it. im not sure what pv stands for.
Old Sep 18, 2005 | 01:40 AM
crmstang's Avatar
crmstang
what is the difference between city mode and not city mode?
Old Sep 18, 2005 | 02:55 PM
acid7711's Avatar
acid7711
Less false alarms and a wider scaning range I think. I personally cut the wires on mine, ran em up through the A arm, mounted it on the windsheild perm and just ran ground to ground and the 12+ to ign acc. wire. Works great for me. I've always had this setup in every car I've owned.
Old Sep 18, 2005 | 05:14 PM
crmstang's Avatar
crmstang
so is it better to have it in city mode when im in the city or have it off city mode?
Old Sep 22, 2005 | 12:18 AM
dan's Avatar
dan
in the city there is alot of things that will trip the radar detector- just look at all the lights everywhere, automatic door openers, etc. when u put it on city mode it helps be more discriminitive and ignore alot of this. turning city OFF will make it more sensitive for when ur not in the city.
Old Sep 22, 2005 | 10:44 PM
gotmineNov04's Avatar
gotmineNov04
I have a Passport and leave it plugged in and on all the time. It doesn't draw enough to run the battery down.
Old Oct 25, 2005 | 03:34 AM
monkeydude3's Avatar
monkeydude3
I got a 97 GT and I leave it in... hasn't run down yet. If yo uwanna be sure just un plug it, it takes you what .5 seconds to un plug and .5 seconds to plug it in....
George
Old Nov 5, 2005 | 04:31 PM
wwmost's Avatar
wwmost
i know on like the cobra radar detecter city just means when you get a signal it will only beap one to worn you untill it gets closer or the number gets up to 3 and then it goes off. and high way just warns you of everything. on my valentine one it has somthing that is called logic and its way better at seperating false alarms with real ones. i love it
Old Nov 11, 2005 | 12:23 PM
TAPOUT's Avatar
TAPOUT
City mode usually doesn't false as much on X band radar signals, which are usually coming from automatic door openers in front of a grocery store. X band is currently only still in use for Radar in New Jersey. I can set my detector to not sense X band on city mode. I switch between city and highway only on longer trips. There is more and more Laser being used, and all the detector is doing for you is letting you know when to pull over if you are speeding. The piece to get now is the Escort ZR3 laser shifter.
