need help with halo headlights..
Old May 3, 2012 | 08:54 PM
one7golf's Avatar
one7golf
Default need help with halo headlights..
i bought a set of roxiom halo headlights from a guy off craigslist. nothing came with the headlights. i installed them with 2 wires not having a place to connect to. to i slpiced them into the driving/marker lights. everything works as it should except for the halo light. i dont know what to do to make the halo light up. any suggestions?
Old May 6, 2012 | 07:14 PM
ttocs's Avatar
ttocs
have you tried switching the wires, maybe you had it hooked up backwards first. IF they are lit by diode they will only light up one way but nothing bad happens from hooking them up backwards.
Old May 7, 2012 | 01:29 PM
one7golf's Avatar
one7golf
thankyou for the input. last night i discovered that there is some sort of reduce that is suppost to plug into the halo light. well i found the adapter at a local junkyard. installed it, and came to the conclusion that the halo light itself is actually burnt out. all the other lights work tho. be carefull what you buy from people off craigslist is what i learned lol. oh and halo lights are a pain. im going to switch back to oem lights
T.M.808
Jul 22, 2006 03:19 PM
mattcooper2005
Apr 27, 2006 12:36 AM
