Backseat amp mounting
Old Sep 21, 2005 | 10:31 PM
v6stang1335's Avatar
v6stang1335
Default Backseat amp mounting
Is the backseat support board strong enough to hold an amp or is the board not dense enough to hold the screws?
Old Sep 22, 2005 | 03:30 AM
Jimmz's Avatar
Jimmz
Default RE: Backseat amp mounting
depending on how big and how much the amp weighs. if its a small amp then yeah if not then its not a good idea. you can do an amp rack like i did, my amp was WAY too big to put in back of the seat, heres a pic..
[IMG]local://upfiles/5195/837D20D9DF924806AA8026F1B4D3E9BE.jpg[/IMG]
Old Sep 22, 2005 | 11:05 AM
sowaxeman's Avatar
sowaxeman
Retired Moderator
Make sure you use as short as possible screw to hold it if you do - you don't want your passengers getting a suprise acu-puncture treatment Plus I'm sure you'd hate to see those screws coming through [:@]
You might consider mounting a piece of plywood (covered in matching carpet of course) across the span of both seats first to disperse the load - then mount your amp to that.
jwog666
Dec 27, 2021 08:09 PM
baddog671
Jul 26, 2016 01:20 PM
UrS4
Oct 3, 2015 06:23 AM
breaking
Oct 2, 2015 01:27 PM
Explosive
Oct 2, 2015 07:45 AM
