Please Help. Power switch problem!
Old Sep 1, 2013 | 06:55 PM
motopenn's Avatar
motopenn
Default Please Help. Power switch problem!
I just purchased a Kenwood KDC-BT755HD for my 2006 mustang gt. I have the shaker 1000 system in it already but I cant use my phone to listen to music so I went this route. I bought the harness I needed to use for the shaker system and all that good stuff. I unplugged the factory 6 disc and removed it. The problem I am having is the (red) wire on the harness that is for the power switch is getting no voltage from the harness. I checked EVERY single fuse in both panels. Is there any place I can tap in from or does anyone know a solution. I ran the red wire to the yellow wire to power up the DU to see if I had all the speakers working. The only problem is that when the DU is in HD Radio mode all my subs work perfectly fine and dandy, but when I switch to Bluetooth they don't work. They only work with the HD Radio source. Why is that? Is there a fix? Ive spent all day on google and cant find anything. Someone please help im going crazy with no music.
Old Sep 2, 2013 | 11:10 PM
epictwist's Avatar
epictwist
If there is no blown fuse, uou could tap an ign fuse in the panel. As far as the sub issue, mostrradio's with bt have a setting where it only works on front speakers. You will need to set it to all speakers. Then everything should work.
djbigskrilla
Sep 20, 2022 01:04 AM
importsmasher
Oct 9, 2015 04:42 PM
1st 4 eyed fox
Aug 15, 2015 02:16 AM
KEM Motorworks
Aug 14, 2015 10:13 PM
drumhedd2005
Aug 13, 2015 09:59 AM
