Mach 460 Amps bad?
Old Jul 4, 2021 | 02:44 PM
ForeverDrivin's Avatar
ForeverDrivin
Default Mach 460 Amps bad?
Hey everyone, quick question and description of my issue.
Ever since I got this car (a 97 GT with the Mach 460) there has been little to no bass and significant "radio buzz" that follows the volume. What I've found is that my front speakers and all tweeters work fine, even the tweeters in the back (with the amps unplugged).
With the tweeters so close, and so little headroom, I'm not too sure if there is any sound coming from the subwoofers at all, but the best bet is probably not. The amp's front black plug (6 pin, only 3 connected tho) has power. A ground, a 12V, and a 5V like it should be, so there is no main power issue.
The headunit is some old Pioneer crap, not too concerned about this right now.
So if my issues persist (the radio buzz and no bass) even after both amps are unplugged and removed, do you think this is another case of Mach 460 amps just dying out, or do you think the speakers may be at fault? Or do you think no bass and the buzz are separate issues? I just assume the electrical signal is getting buzzed by the faulty bass in the system. Any input appreciated.
Thanks!
Cody_754
Apr 23, 2013 10:41 PM
icukev
Sep 30, 2010 09:04 AM
ryanc
Apr 12, 2008 09:37 AM
Black95MustangGT
Aug 6, 2006 04:40 PM
JJ94GT
Mar 19, 2004 01:12 PM
