want to upgrade 2002 stereo
i am a first time owner of a 2002 mustang it has the mach stereo but sounds horrible i know nothing about stereos so no idea what i need i have two 12 inch woofers but can i get some advice on the cheapest way i could upgrade
Could be as simple as needing to replace the speakers. they are most likely 20+ years old.
Simply throwing a bunch of bass on it will not fix anything.
And yes, upgrading a MACH 460 won't be cheap since you'd need to get new amps to replace the factory ones.
Describe horrible.
If he's going to rip out the MACH system, may as well upgrade it right, New HU with preamp outputs to run to amps to run the speakers correctly. DSP optional.
That is true but running speakers off of a head unit will sound terrible too. The distortion levels on integrated amps is crazy.
