Help needed with dimmer wire GT 2005
Old Nov 5, 2005 | 12:30 PM
Bubbamax's Avatar
Bubbamax
Default Help needed with dimmer wire GT 2005
Hello all,
I need help with the wiring of the light dimmer wire.
In the 2005 Gt there is no wire for the backlight dimmer(or at least I can't find it).
My Pioneer CD and my DVD player are way to bright without the dimmer.
Does anybody know a way to have those wired even if it is to be permenent so that i don't have to drive at night with a pair of sunglasses?
Thanks in advance.
Old Nov 5, 2005 | 12:44 PM
Sinister Audio's Avatar
Sinister Audio
Default RE: Help needed with dimmer wire GT 2005
those you should be able to go into the radio itself and dim it. alot of aftermarket radios arnt comming with dimmers because their screens are to complex and they wont work right with a differnt voltage.
Old Nov 5, 2005 | 12:49 PM
Bubbamax's Avatar
Bubbamax
My mistake,
The screens are not the problem. It's the button backlight that's too bright and they will dim only if I hooked them up to the lighting terminal(Headlights ON) but I found out somwhere that the 05GT use some kind of other signal to dim the light in the cokpit.
And I haven't find a solution Yet.
importsmasher
Oct 9, 2015 04:42 PM
bigdaddy51200
Aug 19, 2015 05:09 AM
defarmer
Aug 13, 2015 06:40 AM
'stangdude
Aug 12, 2015 01:27 PM
