AMP
Old Dec 7, 2005 | 11:16 PM
  #51
Hisss04Cobra's Avatar
Hisss04Cobra
says hiththth
Default RE: AMP
Treo engineering > all
Old Dec 10, 2005 | 01:26 AM
  #52
F00Mustang's Avatar
F00Mustang
Default RE: AMP
JL: 300/4
Rated Power (4 Channel Mode): 75 W RMS x 4 @ 1.5 ohm-4 ohm (11V-14.5V)
Rated Power (Bridged to 2 Channel): 150 W RMS x 2 @ 3 ohm-8 ohm (11V-14.5V)
THD at Rated Power: <0.03% @ 4 ohm per ch.
S/N Ratio: >108.5 dB below rated power (A-weighted, 20 Hz - 20 kHz noise bandwidth)
Frequency Response: 5 Hz - 30 kHz (+0, -1dB)
Damping Factor: >200 @ 4 ohm per ch. / 50 Hz
>100 @ 2 ohm per ch. / 50 Hz
Slew Rate: ±25 V / µS @ 4 ohm per ch.
Left to Right Channel Separation: >75 dB @ 1 kHz
Input Range: Switchable from 200mV-2V RMS to 800mV-8V RMS
Dimensions (L x W x H): 13.40 in. x 9.25 in. x 2.36 in.
340 mm x 235 mm x 60 mm
Zapco:
Stereo, 4 ohms: 4x50 Watts
Stereo, 2 ohms: 4x90 Watts
Bridged, 4 ohms: 2x180 Watts
T.H.D. + Noise: <0.032% @ 4 ohms
S/N Ratio: >95dB
Slew Rate: >23V/uS
Damping Factor: >160@ 4 ohms
Dimensions: 18"L x 7.5"W x 2"H
All outputs for DLS amplifiers are measured at <.1%THD, which isn't bad, but it does take it out of the same class as JL and Zapco. Zapco is great product, but it lacks the versitility of JL's Absolute Symmetry system. Zapco's flagship 4-channel, the 1000.4 is a great amplifier, even rates better than the 300/4 and 450/4, but it is way more power than I will ever need, or should ever need for a set of component speakers. I just didn't see the point is spending money for power i'm not going to use. That and the overall length of the amp make it an unreasonable choice for the allready compact trunk of Mustang Conv. I would have no place to put an amp that size. The 300/4 and 500/1 fit very nicely on the floor of the mustang trunk, and still leave room for caps and a box.
JL had the right fit, the right power, and the high quality that i needed.
Old Dec 10, 2005 | 01:44 PM
  #53
Sinister Audio's Avatar
Sinister Audio
Default RE: AMP
DLS underrate their amps to be actually better than they say they are. they are in the same category as zapco and all the other top end companys. and JL has good stuff its just not the top of the line stuff. my bravox comps are alot better than JLs XR series comps and the JLs couldnt take the power from a 75watt DLS amp which actually produces about 125 because they under rate them and they are very reasonable in price actually much better than JL.
Old Dec 10, 2005 | 03:25 PM
  #54
pj1010's Avatar
pj1010
Default RE: AMP
ORIGINAL: Sinister Audio
JL has pretty good products but to say they have the best is a very bold statement. look at zapcos specs if you want to see an amp blow JL's out of the water. JL has some good subs but their is usually something just as good if not better. the new XXX from RE will kill the W7. DLS has amps that are better than JL and alot of them are Cheaper the JL 1000/1 is a 1000 bucks and the DLS A6 is a 1200 watt amp that puts out more power than that and is supper clean for 650 bucks. and DLS has been one of the Top SQ competitors world wide for years now and takes a top place in more than one catagory at every event.
Thank you for saying this. I'm tired of hearing "The people at Best Buy said this sub was the best so I bought it."
Old Dec 11, 2005 | 02:01 PM
  #55
F00Mustang's Avatar
F00Mustang
Default RE: AMP
Considering Best Buy doesn't sell this brand, that's pretty funny.
Another thing, i'm using the new ZR components,not the xr's and 125watts is more power than anyone should every need for highs in as small a space as a car.
Old Dec 11, 2005 | 02:15 PM
  #56
pj1010's Avatar
pj1010
Default RE: AMP
ORIGINAL: F00Mustang
What? Who said they did? His comment wasn't even about subs in the first place. My comment was in reference to everyone buying crappy equipment because Circuity Cuty/Best Buy said it was good. "Billy in the car audio department said XXXXXXX brand components sounded good so I'm ganan go with that."
It's almost pointless to suggest such brands to these people as they do not have the desire/know-how to employ such equipment. If you get a Zapco or Xtant or some ****, you need a good head unit, and good components, and sealed enclosures, and etc etc etc. I'm guessing about .1% of the people on here care that much. I think I spent abot 2200 dollars just to get my two front components working OUTSIDE of enclousures. This kid is talking about a $300 Infinity amp.
Old Dec 11, 2005 | 04:13 PM
  #57
JJ_Stang's Avatar
JJ_Stang
Default RE: AMP
It doesn't matter what someone says sounds good, It is so important to go and listen to as many different brands of equipment as possible, I know that is not possible for some, I must have listened to 20 different sets of speakers, amps, headunits. It is what sounds good to you. I was lucky one of the places I went the owner was installing a system in a mustang and got to listen, and see what I liked and didn't. Obviously equipment does have something to do with it but your own ear is the most important.
Old Dec 11, 2005 | 04:22 PM
  #58
pj1010's Avatar
pj1010
Default RE: AMP
ORIGINAL: JJ_Stang
That helps alot as well. It also helps to know what different sounds should acutally sound like it real life. (i.e. - take a trip to a music store or a recording stuido).
Old Dec 11, 2005 | 07:43 PM
  #59
bonesninja's Avatar
bonesninja
Default RE: AMP
the old XXX kills the dub7 as well.....i know
my box and sub
Old Dec 11, 2005 | 10:19 PM
  #60
F00Mustang's Avatar
F00Mustang
Default RE: AMP
I'll admit it, the XXX is a louder sub than the W7, it better be considering that the 12w7 is rated for 750watts RMS, and anything more than 1200 voids your warranty. Meanwhile the RE XXX boasts 8500watts RMS. So while you out buying alternators and batteries for you car, I'll be pocketing the money toward speed parts. Also, JL as a company does not consider their product to be for SPL use. It is all designed for sound quality, without being something that a second mortgage must be taken out on to purchase. Your compairing a small block ford to an alcahol burning, blown, sprayed, Siameese bored drag motor. Now which one is realistic.
As for the above picture, I'd love to see someone fit something like that into the trunk of a convertible Mustang.
My 10"W7 fits great into their with only 500 watts needed to get everything out of it.
Prior to this woofer, I preferred the Eclipse titanium series for sound quality, but the cone area was too small. JL was the first company to solve the cone problem so that you didn't have a 12" sub with an 8" cone bcause of the size of the surround, and they have the patent on it. The only other sub which has been able to do this is the Alpine Type X series, with their surround that is ridged to expand.
I never said that JL had the loudest sub on the market. I said that it is the best sounding sub.And with small space and without a thirst for power, untill someone comes out with something more efficient that can still produce that level of quality, i'm sticking with it.
