Need a hand with front speakers
Old Dec 3, 2005 | 06:26 PM
jerzeemedia's Avatar
jerzeemedia
Default Need a hand with front speakers
Hey folks!
My speakers blew in the door panels of my 2001 ford mustang v6. I'm trying to find a guide/manual as to how to either replace them, or take off the door panel to get to the speaker. Any ideas or suggestions would be greatly appreciated!
Thanks!
JM
Old Dec 7, 2005 | 01:51 AM
seight311's Avatar
seight311
Default RE: Need a hand with front speakers
Start by popping off the interior part where your side mirrors are, triangle plastic piece. Then tkae the couple of screws out by the door lever itself. Pop out the plastic piece where your window button and slot to pull the door shut is located. Take out the screws along the bottom of the door. Lift up and towards yourself to remove. A little bump and light kick of the shoe may be necessary. Reverse to re-assemble.
Old Dec 8, 2005 | 04:03 AM
03zx2's Avatar
03zx2
quick question what size are all the speakers?
Old Dec 8, 2005 | 01:55 PM
seight311's Avatar
seight311
OEM 5x7/6x8 all the way around, if you are replacing I would recommend 5 1/4" for your front doors.
Old Dec 8, 2005 | 01:57 PM
03zx2's Avatar
03zx2
any reason to go to 5 1/4 for the doors? what size are the small ones near the window?
Old Dec 8, 2005 | 02:01 PM
pj1010's Avatar
pj1010
Round component speakers would be your best bet.
Youre tweeters are probably 3/4" stock. However, you can make a 1" fit in those pods.
Old Dec 8, 2005 | 02:09 PM
seight311's Avatar
seight311
5 1/4" would lead to no cutting of your door. 6 1/2" would be ideal, but some custom work will be needed to do so. And yes the tweeters if you have the 460 you can easily swap out by taking apart the 460 pod and putting in the tweeter from the componet set.
Old Dec 8, 2005 | 05:23 PM
03zx2's Avatar
03zx2
thanks for all the info. my old car i put in tweeters and with the stang i feel i have no highs. so i was thinking of starting to change some of the components.
Matt's 95 Stang
Oct 5, 2015 07:16 AM
UrS4
Sep 30, 2015 10:13 AM
Sixer4Life
Sep 29, 2015 07:03 PM
RCS02v6
Sep 29, 2015 01:46 PM
marc954
Sep 29, 2015 11:18 AM
