1999 AMP Installation.
Old Dec 14, 2005 | 03:16 PM
shady visions's Avatar
shady visions
Default 1999 AMP Installation.
I am going to run my wiring from the battery, head unit, etc, and I was wondering if anyone else has done it themselves? I am trying to run it under my carpet / seats and into my trunk. The only problem I am having is getting to the head unit and getting under the carpet. Does anyone know where a DIY is or can help me? Pictures preferred. Thanks.
Old Dec 14, 2005 | 08:27 PM
p0rsche23's Avatar
p0rsche23
Default RE: 1999 AMP Installation.
i went below the door under that panel thing then around the side of that backseat,not under them but tucked where they cant be seen obviously cuz i couldnt get the wire under the seat althought i bet it could be done,and as for getting to the headunit are u just trying to figure out how to get the wires there unseen or getting to the back of the head unit? if you need to get to the back of it,take ur shifter bezel off and then take the whole front radio bezel off,it brings the air vents and radio with it,not the instrument panel thing tho......u prolyl have a couple clips to get the radio thing onbut i didnt.....I dont know if this helps but noone else responded,and i have a 98 so i dont know if its the same or not....
Old Dec 14, 2005 | 08:46 PM
pj1010's Avatar
pj1010
Pull out the drivers side of the interior.
Old Dec 15, 2005 | 02:59 AM
seight311's Avatar
seight311
Go ahead and drop the tranny too. If you want to make things easier yet, doing an engine rebuild is always easy preventative maintenance.
Old Dec 15, 2005 | 03:21 AM
seight311's Avatar
seight311
Im just kidding man. Check out installdr.com should be a helpful information on there. Otherwise, you ned power, from battery, spade connectors and battery terminals always make things easier. Ground, clean metal area to run ground wire. remote cable will basically act as a switch that tells the amp to turn on when the head unit is. Connects to the blue wire coming out of the head unit. Rca's send the audio signal from the head unit to the amplifier. And of course your speaker wires, and bass **** if applicable. Thats a rough idea of what you need to do. Don't forget you need stuff like a fuse holder, connectors.
Old Dec 15, 2005 | 11:10 AM
pj1010's Avatar
pj1010
ORIGINAL: seight311
Blue wire or blue wire with white stripe, dependent upon head unit.
fcarpio
Apr 30, 2016 05:31 AM
breaking
Oct 2, 2015 01:27 PM
daytooday
Sep 20, 2015 10:55 AM
rdog69t
SVT Forums
Sep 13, 2015 06:16 PM
cbird1177711
Sep 3, 2015 08:43 PM
