Radio installment (help)
Old Jan 26, 2004 | 01:41 AM
zipsayain's Avatar
zipsayain
Default Radio installment (help)
(1997 6cylmustang )Behind the factory radio there are two plugins(one's for power etc, and the second one is for speakers. But there is no volume. Someone told me that their might be an amplifier(with aFUSE out)in the trunk, but I can't find it?</P>
Old Jan 26, 2004 | 03:22 AM
tchamber's Avatar
tchamber
If you bought a new deck, you need to go to Car Toys and get an adapter that will go from the deck to the stock wires. Should cost about $16. Just tell them what car and deck you have.
Old Jan 26, 2004 | 04:36 PM
meowmixxer7's Avatar
meowmixxer7
bigg3st problem i had with my stereo, was getting it out. man that was a pain. then i went to the store and saw they had the 4 prong remover tool. the tools i used were screwdrivers a crowbar and a garden hoe.
Old Jan 26, 2004 | 04:52 PM
SpeedRicer's Avatar
SpeedRicer
the tools i used were screwdrivers a crowbar and a garden hoe.</P>
bahhhhhhahahahaha...<IMG src=smileys/smiley32.gif border="0">
</P>
Old Jan 26, 2004 | 05:16 PM
TheGmKiller331's Avatar
TheGmKiller331
I ♥ Acer
Some wire coat hangers cut to the shape of "U"s work just as good as the tools.If your car has the premium sound and the factory amp you will need the adapter cables to bypass it.Im not sure of yours but mine had that factory amp and premium sound crap and i ended up rewiring anyways for my amps and such so i gutted it.</P>
If it doesnt have premium sound and just the headunit and speakers you need the wiring adapter and you can get this anywhere including wal-mart.Wire the adapter to your new headunits harness and please at the least use shrink wrap if you cant solder it.And then plug it up and go.The wires are all color coded and easy to wire up.</P>
Old Feb 13, 2004 | 01:34 PM
Krusher's Avatar
Krusher
Please visit this site's installation guide if you want to do-it-yourself... I wouldn't recommend it unless you can't afford $7-15 for an adapter that will make things a lot easier</P>
</P>
http://www.installdr.com/Harnesses/Ford-Wiring.pdf</P>
mtgldr
Feb 3, 2024 09:00 PM
Gkid182
Sep 22, 2015 08:17 AM
unit91
Sep 15, 2015 09:53 AM
cbird1177711
Sep 3, 2015 08:43 PM
