Amp remote power wire question
Old Jan 30, 2006 | 12:48 AM
cstigger04's Avatar
cstigger04
Default Amp remote power wire question
OK everyone, I just downloaded the wiring diagram for the shaker 500. After studying the diagram I think I have decided to tap into the #2 wire on plug J1. What do you all think??? Is there a better wire to tap into? Here is the first picture of the wiring diagram
Old Jan 30, 2006 | 12:49 AM
cstigger04's Avatar
cstigger04
Default RE: Amp remote power wire question
Here is Pic #2
Old Jan 30, 2006 | 12:50 AM
cstigger04's Avatar
cstigger04
And #3 the back side of the shaker 500
Old Jan 30, 2006 | 06:16 PM
97BlackStang's Avatar
97BlackStang
The wire in your first post should be the right one. Get a multimeter and find a good ground. Set the multimeter to 12 volts dc put the positive electrode on that wire, turn on the ignition and if you get 12 volts your good, turn off the ignition and it should go back to zero. If that happens thats the wire you want.
Diode Dynamics
28
May 26, 2022 12:02 PM
importsmasher
Oct 9, 2015 04:42 PM
toastintx64
Aug 29, 2015 05:12 PM
movielover40
Aug 27, 2015 10:13 PM
StangMuscle
Aug 12, 2015 07:27 AM
