subs
Old Feb 5, 2006 | 04:46 PM
sandcracker21's Avatar
sandcracker21
Default subs
hi guys.....i was wondering what the cheapest way one could add two subs to the mach460 system
take into concideration i have UDP
Old Feb 7, 2006 | 08:01 PM
sandcracker21
Default RE: subs
any1?
Old Feb 7, 2006 | 09:48 PM
97BlackStang's Avatar
97BlackStang
Default RE: subs
line out converter...... in my experience with it, didnt sound so good.
Old Feb 8, 2006 | 03:50 PM
sandcracker21
Default RE: subs
could you explain this a little better?
Old Feb 8, 2006 | 04:37 PM
1fastzook's Avatar
1fastzook
Default RE: subs
line out converter or a hi lo adaptor you hook it to you factory speaker wires and it converts it to rca outputs but when you hook it to factory radios it never really sounds that great.if you car has amps in it sometime when you turn your radio off you get a pop through the speakers they are availible at most local audio shops if $ is a concern or you dont wont to lose the factory head unit it is the only way to go.i suggest to just yank out that factory head unit and you will have alot better sound quality.hope that helps you out
Old Feb 9, 2006 | 02:16 AM
sandcracker21
Default RE: subs
how bad does it sound? will it be bad for my car in anyway?
also will the UDPs make any difference?
Old Feb 16, 2006 | 04:45 PM
JJ94GT's Avatar
JJ94GT
Default RE: subs
i used a line out converter for my first sub installation, and i didnt think it sounded bad at all, if your gonna wire the converter yourself, be careful, my first time took me like 2 hours tryin to match up all the wires
Sixer4Life
Sep 29, 2015 07:03 PM
cbird1177711
Sep 3, 2015 08:43 PM
cbird1177711
Sep 2, 2015 08:51 PM
cbird1177711
Sep 2, 2015 04:12 PM
