Removing backseat
Old Feb 5, 2006 | 10:28 PM
stangman2354's Avatar
stangman2354
Default Removing backseat
I need to put my subbox in through the opening of my backseats of my car but there is that bar around the opening and it is connected to the backseats so how do i remove them..ands its a 99.
Old Feb 5, 2006 | 11:35 PM
seight311's Avatar
seight311
Default RE: Removing backseat
I have tried explaining this to 50 people and no one ever let me know if my instructions helped or not. If you hop into the backseat, right where the seat meets the carpet, or where the top of your calf would be if you were seated, theres two "pop pins" take two screwdrivers and slide them onto each side of each pion and lift up and pop them out of place, don't be afriad of breaking something theres nothing under there you can damage really.Then the bottom half of your seat will slide right out and then you will find I believe 4 bolts holding the back support of the seat and the bracket holding it to the body of the car unscrew those and there you go, no more back seat.
Old Feb 5, 2006 | 11:41 PM
stangman2354
I will try this tomarrow. I already unbolted all of the bolts for the bracket thing.
Old Feb 6, 2006 | 05:45 PM
stangman2354
are the pins in the middle of both backseats like in the middle of the car or are they dived by each part of the back seats like where each person would sit?
Old Feb 6, 2006 | 07:45 PM
hookandpull's Avatar
hookandpull
ORIGINAL: stangman2354
in the vacinity of where each person would sit. if you do like seight311 said you just take a screw driver and slide it under the seat and then slide it abck and forth to find the pins there should only be two. then when you find one pulup on the part of the seat where the pin is.
mtgldr
Feb 3, 2024 09:00 PM
BOB ROME
Jul 26, 2023 01:54 PM
jwog666
Dec 27, 2021 08:09 PM
Dathan
Oct 5, 2015 05:52 AM
jrrhd73must
Oct 2, 2015 09:17 PM
