Adding subs to mach 460
Old Feb 8, 2006 | 06:18 PM
convertcobra's Avatar
convertcobra
Default Adding subs to mach 460
How does it sound to add 2 10's to the mach 460 system? Is it worth it or should i wait it out and go for the whole thing? Im not looking for anything crazy, as long as it sounds good and the quality of the subs and amp are good. Also what brand subs and amp should i look into if i want to use them with the mach 460.
Old Feb 11, 2006 | 01:24 PM
1fastzook's Avatar
1fastzook
Default RE: Adding subs to mach 460
i would just replace the whole system i have found that no mater what you do you cant get the mach system to sound good .for subs if you want good sq or spl try a digital designs 2500 series you can find them at ddaudio.com
Old Mar 13, 2006 | 01:20 AM
ajspellm's Avatar
ajspellm
i have a 12" alpine type r run off of a kicker kx1200.1 in my car right now. it sounds decent. i have it hooked up through a line out converter until i get money to redo the entire stereo.
Old Mar 13, 2006 | 03:24 AM
Morbid Intentions's Avatar
Morbid Intentions
Wash Rinse Repeat
ORIGINAL: convertcobra
depends on what you plan on running.... if you are a rocker I would go with the 10's... the mach 460 makes a good mix-up of sound in that category with 10's... but If you run bassy stuff... I would go with 12 inch W7's by jl audio and if you wanted to stick with 10's and still want bass go with some DB drives... I mix and match my music and I have mid-quality memphis 12's and I have the mach running on a 4 channel by memphis as well as running the two subs on a peak amp for what the subs kick.... I get alot of compliments on my sound and I would suggest something like that if you want a good treble/bass mix without having to spend too much on dynomat to stop rattle...
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
Oct 5, 2015 07:40 AM
jrrhd73must
Oct 2, 2015 09:17 PM
breaking
Oct 2, 2015 01:27 PM
Sixer4Life
Sep 29, 2015 07:03 PM
