I-pod, headunit
Old Feb 14, 2006 | 09:11 AM
mustangman02232's Avatar
mustangman02232
Default I-pod, headunit
is it possible to set up an I-pod to play directly through to the stereo? if not and i end up replacing the head unit do i need to replace all the speakers and have it rewired or can i just have Best buy slide in a new headunit, as i will not be doing this myself.
Old Feb 14, 2006 | 11:08 AM
4.698GT's Avatar
4.698GT
Default RE: I-pod, headunit
You can use an FM modulator to play it through the factory stuff or you can purchase a aftermarket headunit with an AUX imput on the bak then just purchase an RCA to Mini cable and your good to go. YOu should just do the work of installing the headunit yourself. Its incrediblely easy and only takes a few hours.
Old Feb 14, 2006 | 01:50 PM
mustangman02232
ORIGINAL: 4.698GT
i have the transmitter and it sounds like sh*t. im not doin the install myself id rather get it done profesionally, but i thought you had to do a bunch of work because the amp is built in to the mach 460 or something like that? i dont know im not very good with stereos.
Old Feb 15, 2006 | 11:18 AM
4.698GT's Avatar
4.698GT
Well if your not gonna do the work yourself, I advise you to stay away from bestbuy at least for the install and tell the salesperson that you want your aftermarket deck to have an AUX imput and dont buy crappy stuff!!
Old Feb 15, 2006 | 01:58 PM
mustangman02232
ORIGINAL: 4.698GT
i know not to buy the crappy stuff, im lookin at a pioneer deck but i was wondering if i could just have a replacement head unit droped in and be off clear and free or if i have to drop a bunch of cash on other crap?
Old Feb 15, 2006 | 08:25 PM
p0rsche23's Avatar
p0rsche23
pioneer is crap,lol...i have pioneer[:@][:@]
also, how much is the rca cable to mini cost? u just plug those into the rca plug ins and then into ur ipod and it will work?
Ive had the fm modulator thing too,it was alright until i broke it.those things are cheap made(walmart)
Old Feb 16, 2006 | 12:06 AM
4.698GT's Avatar
4.698GT
the cable should cost no more then ten bucks. You can bypass the stock amps but the sound will be fairly dull if you dont have amps in the system.
Old Feb 16, 2006 | 08:43 AM
mustangman02232
where are the stock amps and why cant i reuse them? so would that mean i have to replace the whole system?
Old Feb 16, 2006 | 09:43 PM
p0rsche23's Avatar
p0rsche23
i think when i had my a/m cd player installed,they bypassed the factory amp...its behind the radio
Old Feb 17, 2006 | 08:47 AM
mustangman02232
ORIGINAL: p0rsche23
so what they cant reuse the factory amp then? why not?
