Componet Power?
Old Feb 21, 2006 | 12:09 AM
MuscleOwnzRice's Avatar
MuscleOwnzRice
Default Componet Power?
Could i run around 4 tweeters and a couple mids of a 45x4 Panasonic Deck and a MRP-T220 Alpine amp? If not whats a solution so i can......
Old Feb 21, 2006 | 12:24 PM
bonesninja's Avatar
bonesninja
Default RE: Componet Power?
you don't really need all that...the more speakers you have up front the harder it is to image/time align all of them which leads to a muddy or possibly hollow/echoing type sound. i would recommend 1 set of tweets and either a set of comps or a set of the mids. you can run 1 set of tweets and one set of comps/mids off of a 4-channel amp. just make sure you high pass the channel with the tweets and adjust the crossover properly for the mids. Most comps and or single good tweets come with a crossover but that is just to attenuate somewhere close to the range it needs to be, you should always cross it over yourself as well.
Old Feb 21, 2006 | 03:39 PM
MuscleOwnzRice
Alright cool, ill look into a set of each. Just got a little confused on the whole situation cuz ive been working with woofers not the actual speakers. But now im at the point where i want to hear the lyrics as well and still hit the high dbs.
jwog666
Dec 27, 2021 08:09 PM
jrrhd73must
Oct 2, 2015 09:17 PM
KingRando
Oct 2, 2015 08:06 AM
Sep 25, 2015 06:58 PM
