Relay for keyless entry to work in foxes?
Old Feb 23, 2006 | 08:43 PM
Champ561's Avatar
Champ561
Default RE: Relay for keyless entry to work in foxes?
How do I save this post?
Old Feb 24, 2006 | 03:01 PM
ricepatrol's Avatar
ricepatrol
Hit "File" then "Save As" then "Save".
I did the same thing, I decided not to make a stupid mistake twice. [:@]
Old Mar 5, 2006 | 03:14 AM
Melectrok's Avatar
Melectrok
the DEI part number for this is 451m. It will be much easier to use that unless your have a good undertanding how the relays work.
Old Mar 5, 2006 | 10:43 PM
ricepatrol's Avatar
ricepatrol
Have you used this relay before? If it's everything I need I will definitely go ahead and buy it. Will I need just one of these to get the keyless to function? Thank you Melectrok, this sounds like it will be easier than fishing for another relay!
Old Mar 5, 2006 | 11:45 PM
Melectrok's Avatar
Melectrok
I have 5.5 years of professional installation under my belt. I have used that one many times. It has two relays built into one package with only 6 wires comeing out and a plug for to plug into a DEI alarm. If its positive trigger you only need 4 wires, but I beleive you have reversing polarity so you will need all 6 one is a ground, one is a power source and two for both the lock and unlock wire.
cbird1177711
Sep 3, 2015 08:43 PM
iamgobono
Sep 3, 2015 12:37 PM
cbird1177711
Sep 2, 2015 04:12 PM
Sep 1, 2015 08:16 PM
