Spark Plug Help!!
Ok, the first 6 came out no problem. This what happened to number 7. The plug is fully intact still in the head. I am assuming that the plug is just stuck since the metal casing with threads came out. How would I remove the plug? Any ideas will be appreciated. I've been soaking the plug hoping it will eventually break free. I also tried long nose needle pliers to no avail.
A very common problem with the 3v cars (and trucks). A few tool companies make a tool to extract the broken plug. I am sure you can find lots of write ups about it on different forums. When you go back with the new plugs, make sure you use one of the new 1pc plugs so you don't have the same problem next time.
lincolnshibuya
Dec 8, 2015 04:37 PM
breaking
Oct 2, 2015 01:27 PM
