Lexington, SC - Brake lights-Shifter Locked
Ok, I have read most of the posts on the subject of no brake light and shifter locked. I have replaced fuses 17, 35, 41. I have replaced the brake light switch. Still not fixed.....
I believe it may be a short or broken wire, one of the two that go to the brake light switch....
That said, I live in Lexington, South Carolina. Any good shops to take the car to that can be trusted to do the work correctly and at a reasonable rate?
Thanks
Thanks
Nope jj I'm not feeling it...jk
Don't go to teals on us1. As far as trusting, I had some warranty work done at Jim Hudson ford without issue, but everything else I've done myself. I would lend you a hand but i'm swamped at the moment sorry.
Thanks clowe1965.... No rush on the repair. The Stang is a secondary car. So, if you can assist at a later date, let me know. If not, still looking for a trustable repair shop. Thanks again !
Yes, the car drive great. Just need to trun the key to ON< shift to Netural, start and drive with no brake ights. I have replace the brake light switch. I belive it is in the wires to the switch.
Monday should be perfect. Thanks.
