Imageready ?
Old Nov 27, 2006 | 03:35 AM
DuFFMaNN's Avatar
DuFFMaNN
Default Imageready ?
Ok so I am making myself a new sig and I decided to try out imageready and see what I would do. I followed AR's write up and it was all going good until I pressed the firefox button (to then right click>save image as) and I got this
Where did I go wrong?
Old Nov 27, 2006 | 03:38 AM
alexr's Avatar
alexr
Default RE: Imageready ?
Old Nov 27, 2006 | 03:41 AM
DuFFMaNN's Avatar
DuFFMaNN
I take it you are talking about the original photoshop document right?
I was thinking that was it but I wanted to make sure before I want back and did the entire thing again
Old Nov 27, 2006 | 03:44 AM
alexr's Avatar
alexr
no no, you dont even need to save the psd file first. when you export the file to your browser, and go to save it, you have to save it as a gif or else it will only try to save it as a still image using just one frame.
Old Nov 27, 2006 | 03:57 AM
DuFFMaNN's Avatar
DuFFMaNN
Thats what is told me WHEN I was trying to preview it in my browser from IR.
I went back and saved it in PS as a .giff and re-did it in IR, and am going to put in on photobucket and here soon
Old Nov 27, 2006 | 04:03 AM
DuFFMaNN's Avatar
DuFFMaNN
I know its too tall but except for that will it run smoothly with these specs?
Format: GIF
Dimensions: 500w x 203h
Settings: Custom, 256 Colors, 100% Diffusion Dither, 94 frames, Transparency off, No Transparency Dither, Non-Interlaced, 0% Web Snap
Old Nov 27, 2006 | 04:09 AM
alexr's Avatar
alexr
yes that will work, and no its not too tall. the max height is 250.
that file size should be fine. you want to aim to stay under 700ish, otherwise loading time becomes noticeable (the file takes longer to load than the rest of the page), and the first time it runs through the cycle it will tend to lag if the file size is large.
Joolander
Chop Shop
17
Jan 8, 2009 11:16 AM
alexr
Chop Shop
Dec 16, 2007 01:58 AM
alexr
Chop Shop
Jul 18, 2007 11:11 AM
alexr
Chop Shop
Jul 17, 2007 10:52 PM
DuFFMaNN
Chop Shop
Jun 18, 2007 10:57 PM
