I believe the T-5 will not require any modification of the tunnel. If you are doing a conversion from an auto you will need to muster up a clutch pedal decide on a cable or hydraulic clutch.
The T5 will fit without modification, but watch your pinion angle. Depending on the rear ride height you may need to modify the angle. The TKO and T56 is bulkier near the tail shaft and it hits the cross brace. You don't have this issue with the T5, but make sure if you upgrade the power output of your engine that the stock T5 can handle the increased torque.
